Been doing some diagnostics on my MGB engine, to figure out if I'm going to do any work on it this winter. Now's the time to make a decision, as I need the car for a trip in May and given my pace of work I'd need to start soon if I have work to do.
Oil pressure: 60ish cold, 40-45 hot depending on how hard I'm pushing the car, can drop just below 40 if I'm pushing hard up a mountain road, climbs back up once the oil cools. Running 20W50
Compression (cold): 110-125-130-130
Compression (cold, wet): 120-130-140-140
Car seems to be running fine other than the (by the book) marginal oil pressure. I've no idea if the power is as it should be, as I have no experience with any other MGB. Leaks a bit more oil than it ought, but it's not the Exxon Valdez.
Thoughts?
I ask as I have no long term experience with these cars, so no frame of reference for what is "normal" running state. Performance hasn't changed in the 3 seasons I've driven the car. Generally runs better now that the dizzy and carbs have been rebuilt.
Thoughts?
