justin_mercier
I almost have the pedal box done. I've got the clutch and break pedals finished so that they meet up with the master cylinder push rods properly (and I'm actually probably going to leave the break pedal bolted like that instead of welding it, so that I can adjust it in the future till I'm happy with it.) Right now i'm using locking shaft collars to keep the pedals from moving side to side, but I'll probably push bushings in there instead when I'm done. On the right hand side where the last shaft collar and empty space are is where I need to trim down and rebush one of the break pedals to turn it into a throttle pedal, which I will then use a cable linkage the whole way over to the carbs, getting rid of the clunky TR6 stock mechanical throttle linkage.
The break pedals , if you actually look at them, are not straight and instead bend to the right significantly. I may have to trim the edge of the pedal box to keep the pedal that I'll be setting up as the throttle from rubbing / binding on the pedal box.
Thanks to Paul Rego for selling me his spare pedal box so that I could get a 2nd clutch pedal to create the off-set from break servo pedal linkage.
