RAC68
A couple of weeks back I started a thread about a lower level in both the clutch and brake portion of the sections of the reservoir. As a result of forum suggestions and physical investigation, only slight sweating was found in the clutch slave and, although it didn’t seem equal to the reservoir loss, the missing fluid could easily have leaked onto the road during a drive. A quick rebuild of the slave cylinder and the problem was eliminated….so I thought.
This past Saturday, preparing for a club show drive, a pre-check of the reservoir showed the brake section was close to half below proper level. This was doubly concerning as a quick check found no lost fluid or any indication at each wheel or line.
Today, I decided to do a thorough investigation and started with de-installing and dismantling the brake booster. I chose the booster since it is the only place that the missing fluid could collect (in the air piston chamber) and stay incognito. Contrary to anticipation, no fluid had collected inside the booster.
One last point, the only place I haven’t considered is the brake master cylinder. The reason for my confidence in the M/C is that no seepage was indicated and no loss of pressure was noticed when applying the brakes.
Since I have already ordered the rebuilding kits for the booster, rear wheel cylinders and calipers, I will continue on that plan. However, I would appreciate any ideas as to where this fluid could be escaping as the brakes were functioning perfectly prior the dismantling.
Thanks all,
Ray (64BJ8P1)
Thanks all,
Ray (64BJ8P1)
