The DPO blues
MGBGT_noob
I've run into my first DPO roadblock, in the process of disassembling my car.
Apparently, during a previous accident, the two bolts inside the grille opening, that connect to the fender, riped out of the engine bay side panel.
If I wanted to fix such damage, I imagine I'd weld a patch onto the engine bay panel, drill new holes, and bolt a new fender on normally. Mr. DPO decided to WELD THE NEW FENDER DIRECTLY TO THE PANEL!!!!
I tried running a reciprocating saw through the joint, to separate the welds (one at the former site of each bolt hole) but they proved tougher than I expected.
Anyone got any suggestions for eradicating welds in tight spaces?
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]
Anyone got any suggestions for eradicating welds in tight spaces? [/QUOTE]
Any chance of getting to them with a 90deg drill and a hole-saw, /bcforum/images/%%GRAEMLIN_URL%%/wall.gif
what-ever-your-name-is???? /bcforum/images/%%GRAEMLIN_URL%%/hammer.gif
/bcforum/images/%%GRAEMLIN_URL%%/cheers.gif
Ed
/bcforum/images/%%GRAEMLIN_URL%%/yesnod.gif hmm, hole saw, that's just crazy enough to work!!!
I just hope the pilot drill doesn't ruin the threads in the fender.
Ed
Hi Noob
Turn the drill around so the cutting edge is facing in. /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
prometalshop said:
Hi Noob
Woulden't that put a hole in your drill?
(ducks and runs) Sorry coulden't help it. /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
If you have a compressor you might want to pick up and cheap air hammer. They normally come with four or five attachments; the straight chisel and the spot weld breaker (straight chisel with a V groove in the center) are the two I use most often.
About $20 at your local builder's mart or on sale for the ridiculously low price of $4.99 at Harbor Freight:
https://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=32940
Ray
And boy do they work.
Ray
I'll see if they have them in stock at my local H-F, tomorrow.
/bcforum/images/%%GRAEMLIN_URL%%/grin.gif /bcforum/images/%%GRAEMLIN_URL%%/grin.gif /bcforum/images/%%GRAEMLIN_URL%%/grin.gif I get to buy more tools /bcforum/images/%%GRAEMLIN_URL%%/grin.gif /bcforum/images/%%GRAEMLIN_URL%%/grin.gif /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
Success!!! [was: The DPO blues]
The Harbor Freight air hammer worked like a champ. I got the fender off, with only slight damage. Hopefully, I can patch up the tears, and reuse this fender.
Re: Success!!! [was: The DPO blues]
Does that GT have a hole in its roof?
Yeah, I guess you could say that. :lol: :lol: :lol: :lol:
Don't forget "the Beast of the East"
Great.
Tears do happen but can be minimized. Watch carefully to see if the weld is being cut or pulled by the chisel. If it's being cut a couple minutes with the hammer and dolly is usually all that's needed to straighten out the area. If it's pulled, a soon as a tear begins, back out the chisel and, if possible, reinsert at 90 degrees to the first effort; repeat two more times. Normally, a small pencil eraser hole is all that will result; this is no more than drilling for a plug weld and is is usually easily filled.
Glad you had success!
Ray
Are you taking this one down to a shell? Im going to have to replace both rockers, the wheel horns and probably the front fender attachments next to the wheel horn. They are not totally gone but there is some definite repair needed.
I plan to strip it down to the point where I can get it blasted, before I try to get the new roof welded on.
For a car that has obviously spent so much time outdoors, unprotected, and didn't receive the kindest of treatment before it went out to pasture, I've found surprisingly little "serious" rust. But, the media blaster may reveal more than I can see in it's current state.
What did you wind up doing about the roof?
A local club member has parted out a number of GTs. He saved the roof off of one, and I just need to wait for last year's bonus to come in, before I buy it off of him.
Thanks for offering before.
