The big brass drain plug on the OD does not thread in easily. I might get ¾ of a turn by hand then I need to use a wrench. I am using a piece of angle iron with a notch for the wrench. I would feel better about tighten the big bolt up if I could get it to go in by hand then do the last with the wrench, but it is not happening. I guess I am looking for some ideas and suggestions. I could by new for 115.00 or maybe file the threads on the big plug a little sharper and see if that helps. Or just go for it and wrench it in most of the way then tighten up until it stops. I just hate fits that are not smooth. Perhaps these big plugs always feel difficult--- I just do not know.
Also the configuration of the screen looks different than the Moss sales book. I basically have the screen and the plug, but there is a bolt up in there that could come out and also no magnets at least none that came out with the screen and plug.
Also I am replacing the home made gasket of leather I made because it leaked with one or 2 of the store bought gaskets, but it looks one might all there is room for because there only 3 threads on the plug, but I could fit it I guess and maybe I should because of the difficulty of the plug.
I noticed a metal plug off to the side of the big plug that is leaking also. Do these things leak like on all Triumphs or I am lucky. Incase no one had this one. Do you know why Triumph never built a toaster? Answer: because they could not figure out how to make it leak oil.
steve
steve
