You might want to add electric parking brakes to the list.... what's so hard about stepping on a pedal to set the brake?
Hi Guest!
DrEntropy said:JPSmit said:DrEntropy said:If I were King, automatic transmissions (and air conditioning) would be outlawed.
And FWIW Doc, that doesn't even enter the top ten list of why I am glad you aren't king.![]()
That said, all the cars in the family are currently stick - and the next ones will likely be automatic. Mostly 'cause stick in heavy traffic is a PITA. So is a car without AC even in Canada. When you live in a city like Toronto, stick just doesn't make much sense and let's face it, automatic is miles better than it used to be.
BUZZKILLER!
JodyFKerr said:I agree Doug. I loathe automatic daytime running lights and any other "feature" designed to take my control of the vehicle away from me.
On the flip side I've been wanting auto manufacturers to put potentiometers on brake lights for years. I want to instantly know whether or not the twit ahead of me is standing on his brakes or just resting his foot there.
TOC said:You don't notice that most of the DRL's are so danged bright you can see the shadow of your head on the sun visor? Or, see the outline of your car on buildings? In broad daylight?
Have to dim the rearview mirror in daylight?
Or, so blinded at dusk in the sideviews when making a turn at a 4 way stop, you almost have to get out of the car to see if there are pedestrians?
Those DRL's?
AngliaGT said:And what can you do to disable them when you have a-
low battery?Or when you're parked,& don't need them?
- Doug
When the e brake indicator light on the dash is on,DRL'S are off.Most DRL's run on a reduced voltage,somewhere between 6 and 8 volts.Some vehcles the DRL's are wired through the signal lite circut so the headlight goes off when the signal light is activated.
The whole system can be deactivated by pulling the DRL relay at the fuse panel.Illegal around these parts though.
I also have two pick-ups, 05 Ford F150 and a 07 Dakota that are leased to a traffic control company. These trucks run 10-12 hours a day with flashing lights, sign board,four ways etc. so e brake must be set to kill headlights otherwise the charging system will not keep up to usage.
