shortsguy1
Sorry if I have caused confusion. Steveg kindly looked up the price from DW and one comparable (via Amazon.com). Using those prices, it hardly makes sense to buy from BMW. I poked around a bit more and found prices for the fan as low as $31 plus shipping. Or it would likely be $41 directly from BMW. So that is somewhat cheaper than DW, but it still leaves the question of the round metal plate that DW appears to include with the fan. So you are saving a little money, but will need to do some of your own manufacturing to match the item sold by DW. The purpose of that plate is clearly to stiffen where the fan interfaces with the existing fan bolts. Keoke addressed his solution to this problem above, though he was discussing the Texas Cooler.
So just to be clear, you may save a little money if you buy the fan from BMW (or BMW parts vendor), but you will have to figure out how the ensure the interface between the fan and the Healey engine is adequately strong. Clearly DW concluded that more reinforcement was necessary, so when you buy from them, you take advantage of their expertise.
