Testing tranny/OD TR 3 A -PRESSURE TEST DONE!!!!!
Re: Testing tranny/OD TR 3 A
"Now I just need to figure out how to post pics"
Hey, now I can help you with that. When you are doing your initial post go to the bottom left and you will see "file manager". Click on that and it will open a window which will allow you to "browse" your files. Click on the picture you want, go to "add file" and if you are done click on "done adding files". That should do it. You should already have your picture sized down to 600 X 460 or what ever your editing program does. If you don't, the forum program will tell you that you are trying to add to large a file. At least thats how I do it.
Cheers, Tinkerman
Thanks, Dick. That's what I've been trying, but can't make THAT work either. Unless.........
SidescreenTR said:
Unless.........
I see what I was doing wrong. I expected the pic to show in the preview, but it doesn't.
See? If you keep all your connections clean and firmly seated, even Lucas stuff works! Umm...sometimes. Thanks! :cheers:
Pretty car !
TR3driver said:
Pretty car !
Isn't it? Too bad it's not mine. I looks like my first car and since my current one is in a zillion pieces, I just found a pic to use as an avatar.
OK, how did you use it as an avatar?
Need steps please. When I tried to set one up I could not get a picture to be small enough.
Thanks, Tinkerman
Thanks, Tinkerman
I just resized it with Photoshop. If you need help, just post a full size pic of what you want and I'll see if I can fix it for you.
you can do anything you want with the right program
