nevets
My OD has not been engaging for some time and I determined that the problem might be the transmission switch because I could not hear the solenoid click when moving the shift lever into 4th, with ignition on and the dash switch in the OD position.
So I removed the old switch and installed a new one, and bingo, I could hear the solenoid click! When I examined the old switch, I could see a very pronounced flat spot on the spring-loaded ball. I'm guessing the flat spot was the reason why the solenoid was not being energized.
But, before I do a road test, I was wondering if it is considered ok to try it out with the car still up on jack stands...as in start the engine, shift into 4th then flip on the OD switch? I'm tempted to try but a bit concerned about safety.
Oh, and a shout out to John Turney, who in another post, pointed out that access to the OD transmission switch is possible from below, eliminating the need to remove the transmission tunnel. Yuge time and bother saver!
