Testing a 6cyl Tacho [electronic] ??
britishcarfreak
How do you test a 2000/2500 electronic tacho?
There's an earth on the body of the tacho and theres a flat spade terminal and a plug type terminal.
What does what? Anybody know?
To test one do I run a lead from the coil to the spade bit or the plug bit in the back? Should the ground be connected to the tacho body or one of the other bits?
Help - Help.
Someone I know has a busted tacho and I'm about to go through a box of spares to find a good one.
piman
Hello Glen,
there are two distinct types, the one you are describing sounds as though it may be the earlier current sensing type. This is identified by a white wire on the back, one end with a female bullet connector, the other male. To test this type connect 12 volts to the two lucar spade connectors, negative to the case, of course.
You then need to disconnect the coil supply and connect to the white wire (I'd guess at the male bullet, and then connect from the female bullet to the coil. The coil current is sensed by the instrument.
The latter type has the same 12v supply connections plus another spade (It may be smaller in size, this just needs to be connected to the coil negative terminal, i.e. the distributor connection. I can't remeber exactly but there are probably some identifying legends on the case for termination.
Once connected, run the engine and compare to the car's tachometer.
Hope that helps,
Alec
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
K TR2/3/3A Testing spark plug wires..... Triumph 11
D TR2/3/3A Tr3 horn testing and wiring Triumph 8
MadMarx Wedge Testing on Airport Triumph 0
nevets Testing OD with Car on Jack Stands Austin Healey 9
HealeyPassion EFI AH testing/tuning remotely Austin Healey 2
FlyingCat Spitfire Smoke Testing Triumph 12
S Testing and Adjusting procedure for RB340 Austin Healey 4
C Testing heater core Austin Healey 9
doc50 Mash Metropolitan Generator testing Other British Cars 1
JimLaney Bench Testing starter Spridgets 8
K TR2/3/3A Compression testing again... Triumph 4
steveg PCV Valves - testing Austin Healey 8
B General TR Testing the Waters Triumph 5
K TR4/4A Generator bench testing..... Triumph 6
Griz Testing Vacuum Advance Austin Healey 5
D TR4/4A Testing the starter Triumph 4
K TR2/3/3A Wiper motor testing? Triumph 7
DornTRoriginal TR2/3/3A T4A Type OD Transmission Operation Testing Triumph 6
D Testing crankcase oil Austin Healey 4
P Bench Testing a wiper motor???? Spridgets 3
M Healey Overdrive Bench Testing Austin Healey 2
Gordon_Dedrick Testing an A type overdrive Triumph 20
B Battery/generator issues - Testing generator Austin Healey 16
jlaird Testing the Pic upload Spridgets 1
K TR2/3/3A Testing a TR3 lever shock? Triumph 7
I Fuel sender unit testing Triumph 2
T Bench testing a coil Austin Healey 3
K TR2/3/3A TR3..testing wiring..leaving key on..Petronix? Triumph 3
KVH Final Testing of OD Triumph 2
Lynn Kirkpatrick Testing Fluids MG 3
S trouble shooting not working speedo or testing one Triumph 22
I Help testing motor Triumph 5
coj Testing send Austin Healey 2
Michael Oritt Dyno testing Racing 5
bigjones Testing Temp Sender Spridgets 5
Tinkerman Bench Testing a Wired Instrument Cluster Triumph 7
MadRiver Testing Compression MG 1
K TR2/3/3A TR3 Erratic fuel gauge finally quits....testing? Triumph 4
R bBJ-7 testing fuel tank float Austin Healey 2
W Reminder about testing sending units Spridgets 8
R DEQ testing/passing & exhaust gas analyzer Spridgets 7
Tinkerman Bench Testing Electrical Components Triumph 13
wkilleffer Testing the fuel gauge MG 3
Tinkerman Testing Brake Lines? Triumph 1
B Lifter/ Rockwell testing results MG 14
R MGB Testing temp sending unit 1979 MGB MG 6
vette Testing w/pictures again Austin Healey 9
7 question after testing a J type overdrive Triumph 5
T Brake Drum Temps - Field Testing Triumph 10
