germanmichel
Hello all,
everything is fine in the world?
For me it was very difficult today to take decision.
Today I want to change the timing chain tensioner. But the old timing chain tensioner (shown on left side on the picture,you can see only dirt in the hole) has an orifice designed by a step hole diameter 3mm into diameter 1mm.
The new tensioner housing (right side) has only a 3mm go through boring.
Can I use the new housing without oilpressure risk ?
Pic shows the motor contact area:
The old housing has a worn sliding bore,so I have to use the new one. But I think I have the risk, if the sliding bore of the new housing is also worn,the oilpressure who support the tensioner tappet can running away through the tensioner housing . So what is the reason of the 1mm orifice, or the reason of the stemped "2" ? :confuse:
Thank you in advance for helping I will play
for the right answer.
Bye- michel who appreciate this competent forum. :thumbsup:
for the right answer.Bye- michel who appreciate this competent forum. :thumbsup:
all for "overnight" support .
,as long as the sliding bore of the tappet is not worn.
