I would like to rig up an SPDT 3 way toggle switch to operate my turn signals while I repair the steering control head. Is it possible to run the green/white wire to one side of the switch terminal and the green/red wire to the other side of the switch terminal ? Could I then run a lime green/red wire for the flasher to each side of those terminals? I assume that the middle terminal would be ground. Would this work? Not sure about the flasher hook up? Anyone familiar enough with the TR3 wiring to know if this is doable? Karl
