R6MGS
After finished the body work, went to move the LE and the temerature gauge is not working..same goes for the fuel guage but that only work half the time anyway....Thinking it was a fuse I checked and replaced all four fuses in the main fuse box and the two in the white plastic connectors found just below the fuse box....Still not working....I am begining to think this car is cursed! I checked the connections to the guage and enverything looks good. So now I've read every shop manuel I've got and still cannot get a good direct to move in....I've read about the Bi-metal resistance equipment and to my understanding the fuel and temp gauages are connected to a voltage regulator(WHERE IS THIS REGULATOR???) I guess failing that the only other thing I could check/replace is the temperature sensor itself(I did check the connection to it and it looks OK) Is there anything else I should check before I replace the temperature sensor??
Thanks
Zack
Thanks
Zack
