wifegonnakillme
I was testing my temperature gauge with a kettle of boiling water last night. The resting temperature seems is on the notch between 90 and 185F, or about 135. If i put it in cold water it will go down a bit. Hot or near boiling water will make the needle climb up to and past 230F...
Is it possible to calibrate the gauge or is it better left to the professionals? I think it is necessary since the car has not been on the road for a number of years (in the body shop now) and I want to have faith that i'm not going to overheat it on the first run out.
Thanks in advance,
kerry /ubbthreads/images/graemlins/canpatriot.GIF
BTW I'm looking for reasonably priced amp and fuel gauges too if anyone knows a source (for a driver)
Thanks in advance,
