Rob_P
Myestery solved, problem discovered.
Now I know what that loose green wire was supposed to attach to.
Unfortunatly it looks like the male end of the temperature sender has snapped off.
Is this worth trying to repair or should i just replace the sender. (and if that is the case, are these the type of products i should order 2 of?)
Rob
/ubbthreads/images/graemlins/nopity.gif
Rob
