Re: Temp guage not working HELP
Baz, the rise in temp post shutdown is normal. There's no coolant flow through the radiator, so the residual heat transfers directly to the stagnant coolant, heating it faster than it can dissipate through the iron of the engine. Not to worry.
A couple of years ago, I was racing a Spit, and had two races about 20 minutes apart. I had an overtemp warning light on the thing, and when I shut it down after the first race, it would heat soak to the point of turning the light on. The switch wouldn't reset itself until the temp dropped below about 180, so, as 195 was the normal operating temperature, I would have to drive the second race with the light on, even though the temp was perfectly normal. Annoying, to say the least.
Jeff
