Technical Question - Steering Lock-to-Lock
tony barnhill
Great Pumpkin - R.I.P
I know the early MGB's had 2.9 turns lock-to-lock & the later rubber ones had 3.5 turns
...but, somewhere in the recesses of my mind I think I've heard that there was a short time when getting a steering rack with 2.4 turns was possible....I've got to of the early racks laying on the floor of my garage....one is 2.9 (just turned it & counted) but the other appears to be less...they both have all the same numbers except 1 place on the housing there are stmped numbers that are different (this is the only rack with the different numbers)
...here's my dumb, technical question: how can I tell if I've got a rack with shorter turning radius?
Tony,
try measuring the distance the the tie rod moves with one revolution of the wheel, the more it travels , the quicker the rack.
mark
Did that, Mark, & it appears it moves farther on one than the other...
Tony
I could be wrong on this but if you have them check the special tuning handbook I'm pretty sure that BMC did a lower geared rack as part of it's tuning kits.
regards
DUH!! Thanks, Tom...I've got one of the handbooks out in the garage - didn't even think about it....
So, I went out to the garage & made a little measuring wheel I could slide over the steering rack to measure lock-to-lock turns...they're all either 2.9 or 3.5
Doc, would you measure the one I sent you, please?
they're that many turns? I'd swear the one in my '76 is less turns than that... I'd reckon the one in my car to be 2.66 turns...
[ QUOTE ]
[/ QUOTE ]
As soon as BOB makes it 'round to this side I'll report back.
MMC: 2.9-ish here, stop-to-stop. Same for the one I removed.
[ QUOTE ]
[/ QUOTE ]
You DID mean a lower gear ratio lock-to-lock here, I'll assume /ubbthreads/images/graemlins/wink.gif
hehehehehehe
