twas_brillig
We have a 1962 A-H BJ7 (roll up windows) that has been in a shop for about two years. During this cycle (plus previous years) we've made the following modifications:
Steering & Suspension
- Norman Nock front turnnion bearings
- polyurethane bushings from Udo Putzke
- Moss camber etc. adjusters
- slight negative camber alignment
- Udo Putzek Fahrspass Bilstein tubular shocks
- Moto Lito steering wheel
Driveline
- Toyota 5 speed all synchromesh transmission
- Lempert 3.54 gear set
- speedometer modified to match the above
- Redline trans/diff fluids
- 5.5" wide 72 spoke chrome wire wheels
- Vredestein Sprint Classic 185/70 HR15 89H tyres
Safety
- 4 way flashers
- LED tail/brake lights
- moved signal lights up to replace the rear reflectors
(I consider these two items (signal lights and LEDs) as essential improvements)
- three point seat belts
- quarter light rear view mirror
Convenience
- moved windshield washer fluid container from glove shelf into space in subframe under right front fender
- cigarette lighter/power take off installed on wood behind 'chicken handle'
Cooling
- triple core rad
- stainless steel fan and shroud from Norman Nock
Engine
- K&N air filters
- spin on oil filter
- Pertronix ignition
- modern pointless fuel pump
Brakes
- vacuum power assist
- braided stainless steel brake lines
Remaining ToDo:
- radiator fluid recovery
- raise front edge of stock seats
I would appreciate hearing from others as to their 'tasteful upgrades'. Thanks!
Driveline
Safety
- 4 way flashers
Convenience
Cooling
- triple core rad
Engine
- K&N air filters
Brakes
Remaining ToDo:
