TR2/3/3A Tar Topper
Skidude
I previously posted a thread about batteries for TR3As because my Optima battery was getting old - no problems - just way past it's projected useful life.
Well - it happened - went out to start my car a little while ago - so dead it didn't even groan.
I was going to try to find a more authentic looking battery - but had such good luck with the Optima battery (red top) that I think I'll just replace it with another Optima and order a Tar Topper to cover the modern look of the Optima battery.
My question is - the Tar Topper offers the covers with fake filler plugs in yellow, red, blue and green - no black or white. Which of the colors is the most period correct to what came in the cars when new?
My car is Winchester Blue if that makes any difference.
Also - would you recommend I get a Red Top or Yellow Top Optima battery - or is there really and difference? The cost difference between the two is minimal.
I've always went with the redtops, but here is the difference straight from Optima...
https://www.optimabatteries.com/en-us/support/battery-basics/compare-redtop-vs-yellowtop-battery
Basically, the redtops are "starting" batteries, yellowtops are deep cycle batteries which are great for when you're using a lot of accessories when the engine is off.
Is it fair to say the yellow is better for infrequently used cars? I.e. it can withstand a deep discharge?
Obviously a trickle charger is a good idea regardless of battery used, to reduce load on the generating system. But for a car that sits all winter, even with the power disconnected, the battery voltage may drop a lot. A charger then can boost the battery before the spring driving season.
Not necessarily. Red tops do not lose their charge anywhere near as fast as regular batteries. I've had an Optima red top in my TR3 for about seven years now. It sits in the garage for at least four months without running. I leave the battery disconnected during that time. I generally just put a 10 amp charger on it once during that time for a couple of hours, and then before I wake it up in the spring. I also have a Miata with a red top in it that sits for months at a time. I haven't done anything with it for about five months, just went out there and checked the battery voltage and it's 12.1 VDC. That battery is about eight years old. I guess it's getting time to charge it up and go for a drive. :fat:
