Celtic 77
I have a 77 B with a Weber downdraft and am trying to organize the multitude of various hoses. There is a clear plastic line from the tappet cover to the Weber. When i take the air cleaner off, there is a lovely mist of oil that I assume is being sucked into the carb to reburn. Is this necessary? Too bad this mist couldn't have been redirected to the rocker panels! Final question: There is a water line from the rear of the cylinder head to the heater pipe that I assume was for the old Zenith. I want to use either as rubber plug on each end since it seems to be just redundant. I will ultimately have one straight heater pipe from the heater to the radiator hose. Thoughts?
