Earlier in my restoration I thought I had sorted this problem out, but tonight it has come back to haunt me again. I have just installed my newly painted rear shroud and I was installing and hooking up the tail lights. By the way, getting those chrome trim rings to fit inside the rubber housing was a real pain!
Here is the situation: All components are new( flasher canister, relay (electronic variety, not the original coils), lights and bulbs). If lights are off and turn signal is activated, both left and right tail lights operate perfectly. If I turn the driving lights on, the turn signal in both lights is barely perceptible. I have carefully checked my ground connections throughout the car, and removed fresh paint where ground connections are to be made, but it doesn't seem to have affected this issue. If a faulty ground was the problem wouldn't the flashing signals have failed when the running lights were off also?
I would appreciate any suggestions that I might try to solve this problem.
Thanks.
Lin
1960 BT7 in restoration
1959 Bugeye
Thanks.
Lin
1959 Bugeye
Hi Guest!
