Tackle wipers or turn signals next?
tdskip
OK - no rest for the wicked here. Need some turn signal action baby, I want to warn people before I dashingly cut them off in my roadster....(kidding)
But being able to use the wipers, even in SoCal, would be nice.
Any comments on which to go after first?
TR3driver
Great Pumpkin - R.I.P
:iagree:
Ain't gonna be raining around here for a loong time; but turn signals are a must.
NickMorgan
Now I know which I use most in Scotland, but I think I would rather the indicators were working. Rain-X does a great job!
T
tdskip
if it turns out that it is the flasher unit, I've heard that the flasher unit in the passenger side foot well can be sourced at any local Napa. Yes?
TR3driver
Which car ? The TR6 used a 2-terminal flasher that is readily available; but the TR2-4 used a 3-terminal that is somewhat harder to come by. Many of the 3-terminal units listed for this application do not work correctly.
IMO the flasher is the least likely source of the problem anyway. I'd suggest jumpering across it (two parallel terminals for the TR2-4 unit) and getting everything else working (turn lamps should light solid with the jumper in place, making it easier to check voltages, etc.). Then if it quits working when you remove the jumper, replace the flasher.
A Tridon EL-13 will work with the TR2-4 circuit, but lacks the mounting tab. The case is also plastic and I found that, over time, it would crack and break from the pressure of the clip I used to mount it. I finally rewired the indicator lamp on my 3A, so the common 3-terminal thermal flasher would work.
T
tdskip
Sorry Randall - this is for the 1974 TR6. So connect the inputs into the flasher unit and start testing from there?
T
tdskip
OK - jumped unit and the lights turned on solid one side at a time when I flipped the turn signal indicator from left to right.
Sounds like it might be the flasher unit, no?
Don Elliott
I can't say for a TR6, but whenever I had trouble with the flasher unit on my 1958 TR3A, I would manually click the flasher lever back and forth and the correct corner directional light would flash. It got me home safely several times. Also if this happened on the way to a concours event where the judges check that the lighting systems, as well as the flashers, you flick the lever as described above and because the judge is looking at the lights at all four corners of your car, he doesn't notice that you are clicking them manually yourself while you are sitting in the driver's seat.
In this case, I would set my priority with your wipers.
TR3driver
Yup, time to change it.
drooartz Parts in, ready to tackle brakes again Spridgets 5
S TR2/3/3A TR2 and early TR3 wipers Triumph 7
M Windscreen Wipers Parking Spridgets 4
R Mounting wipers Austin Healey 8
J Windshiel wipers Austin Healey 13
J Windshiel wipers Austin Healey 3
P Bugeye Windshield Wipers Spridgets 7
HealeyRick Wipers Won't Stop Spridgets 6
K TR2/3/3A Windshield wipers again..... Triumph 8
rjc157 Windshield Wipers Austin Healey 0
L TR6 No power/not enough power to turn signals, wipers Triumph 8
G TR2/3/3A TR3A Electrical Quirks, Flasher, Wipers and Fuel Guage Triumph 4
Crankshaft TR2/3/3A Loss of power to wipers ad turn signals? Triumph 11
B How do wipers mount to scuttle top on a 100-6? Austin Healey 16
rjc157 wipers Austin Healey 4
D Wipers Restored Spridgets 6
Newkie MGB MGB wipers MG 8
S TR2/3/3A windshield wipers tr3 Triumph 1
doates Windshield Wipers Triumph 2
T TR#3windshield wipers and washers Triumph 6
Bob Claffie Windshield wipers Triumph 8
glemon Wipers Arghhh! Triumph 3
jdubois Well, my wipers don't work! Triumph 10
RichBall Working top and Wipers Spridgets 7
John_Mc Wipers and Heaters... Triumph 5
Ohiobugeye Windshield Wipers Park Backwards Spridgets 4
Gundy Inside wipers? Spridgets 12
CraigCootsona Wipers slowed then stopped. Any thoughts? Spridgets 6
L Midget wipers slow and stopping Spridgets 2
M Wipers parking in the Up position Spridgets 11
I 60 BE windsheild wipers Spridgets 4
T Now that the turn signals are working, wipers? Triumph 2
AUSMHLY Got intermittent wipers? Austin Healey 2
Bob Claffie Wipers Austin Healey 10
T Spitfire Spitfire windshield wipers getting old and slow Triumph 15
78Z MG TD like window wipers? Restoration & Tools 3
J Winscreen wipers Austin Healey 4
emann Wipers - how should they spin Spridgets 3
jlaird Question on wipers Spridgets 5
msoylemez BE Wipers are exactly reversed Spridgets 20
B 3 Wipers, 2 good, one is lame... Spridgets 0
zimmy wipers Spridgets 3
D Wipers won't park Triumph 2
R Wipers MG 13
Taz windshield wipers Spridgets 4
A TR4/4A TR4 windscreen wipers Triumph 8
rulle7 'Crunching' wipers Spridgets 3
AltaKnight TR6 TR6 windscreen wipers Triumph 5
Alan_Myers TR4/4A Two-speed wipers, TR4 Triumph 8
J wind screen wipers Austin Healey 9
