GTP1960
While my '60, 3A. Starts very well and seems to idle pretty well.
There is approx. 700-900 rpm discrepancy between the tach & the meter.
( so I'm wondering which one to believe.)
she is still running rough between 2k-3k rpm on the tach.
( hesitates & misses) but. Runs well above about 2700.
no vacuum leaks, timing seems good.
i plan on rebuilding my H6 carbs, because I don't know when it was last done & want to get a base line history going.
I' m going to try to attach a short video. Though I might try uploading to YouTube if this doesn't work.
https://youtu.be/C01qFqNVzAY
hopefully the engine sound will come thru also, because i've adjusted the valves and have a bit of clatter going on. I would like to know if I should try to adjust the valves again, or if a little clatter is ok.
your opinions are appreciated
