The other day my tachometer (1959 Bugeye) suddenly made a serious ticking and it stopped working. I assumed it might be the cable or even the generator gear-drive. Pulled all that out and verified all was well. Never thought it might be the tach itself. Pulled the tach and, yes, it seems to be seized at least a little bit. I put a small screwdriver in the output (where the cable goes in) and it is very hard to turn. Odd that the cable didn't snap with all the resistance.
I've since put in some "Deep Creep" to the outer part that the cable goes into, hoping to loosen it all up and get it lubricated. Maybe it just developed some rust in there (and it did look a tiny bit rusty). After it has set for a bit (and I've manually turned it with a screwdriver), it will move some, but there is more resistance than I would have ever thought there should be.
So, my question to the community is:
a) does this happen much? I've never experienced it.
b) should the output turn VERY freely (when normal)? I presume it should be effortless.
c) am I nuts to open this up and try to salvage it (as I'm trying)?
d) can I take this even further apart?
e) should I just start looking for a replacement?
See attached pic where I've taken the cover off and removed the guts.
Thanks for any replies.
Hi Guest!
