Tachometer reads high when engine compartment heats up
why
My tach when first going reads steady and right RPM, when engine warms up, tach reads high, under dash feels ambient temp, took out of dash, set on seat and same thing, read fine until engine starts to show temp, it seems as engine hotter tach gets higher, oh, original distributor and other parts. any thoughts? Thanks, Jay '65 3000
Check the coil, I've had similiar issues with the tach on my BJ8 when the coil got hot.
My Tach was the exact opposite. I ended up having to have it rebuilt by Nisonger and they upgraded it to handle pertronix and other performance ignitions and now it works great. My ignition is stock except for pertronix and Bosch blue coil.
Hi Jay,
Your's is not a unique experience with the Smiths Tachometer as there is an issue with an internal leaking capacitor that has caused issues as you described. I believe it was an article by Jim Werner that I followed to replace the fractured .22uf Capacitor and recalibrate the tachometer after the quick and easy parts replacement. The replacement electronic component was no more then $1.50 and the unit has remained accurate and stable for the past decade.
I suggest you take a look at the 2004 British Car Forum post made by "Shorn" describing his Smiths Electronic tachometer issues and resolution.
Sorry, but I seem to have misplaced the article I followed, however, Frank Filangeri has an article "BJ8 Tachometer Reading High" posted on John Sims Healey6 site (www.healey6.com/Technical/Werner/BJ8%20Tachometer%20Reads%20High.pdf) that goes through describes the process. Also, there are 2 other articles that address the rebuilding and technology of the Smiths Electronic Tachometer.
All the best,
Ray(64BJ8P1)
