zimasprite
Hey guys,
I'm trying to get my tachometer to work with the crane ignition system. I'm done a bit of reading in past posts but still am not sure how to go about getting it to work. The white ignition wire/loop has continuity to the distributor, the green has power when grounded to the black. No reading on the tach whatsoever. It's an RVI style tach.
1) Will this tach work? If so, how should I hook it up different?
2) If another tach works, what kind and how should I hook it up?
3) Are there any aftermarket options like VDO, etc that work?
Thanks again - Drew
p.s. Primer is here, new wheel cylinders are here, interior panels about done! Getting there....
Thanks again - Drew
Hi Guest!
