FR Burkhart
I can't get the two tachometer lights to work. Other dashboard lights (speedometer, gauges) work but I can't get the 2 on the tach to work. The sockets are a single wire and I can get the bulbs to light outside of the tach if I hold a ground to the bulb socket. Also on a voltmeter,I get 6+ volts when touching the center contact with the one point and ground with the other.
I have run a ground wire from the tach to a ground connection using one of the posts for attaching the tach. Is there a trick on how to ground the tach. It would be great to replace the sockets with a two wire connector but I can't locate any sockets that would work.
The tach is still in the dash so getting my hands around is a challenge but doable.
Suggestions, where to go. Thanks to all who have an idea that would get me some light on the tach.
Thank all,
Frank Burkhart
Thank all,
Frank Burkhart
