Chris_Masucci
Hi Folks,
I recently converted to negative ground and added an alternator. I reversed the loop on the tach and swapped the diode around and it works just fine, including the red charge light. That is until I switch on the panel lights. As soon as I switch the lights on, the tach needle drops to zero. I don't actually have any of the exterior lights hooked up yet, but all the wires are taped off. The gauge lights all come on as expected.
Anyone ever run into something like this before?
Thanks!
Thanks!
Hi Guest!
