budk1953
The 79 Midget has a 3/4" front sway bar with the solid aluminum bushings, one of which has snapped the weld to the body and looks a little damaged. If I replace these I know I have different choices, aluminum again, hard urethane, poly, with or without grease fittings. Since the underside of the main beam is torn where the weld is I plan the attach a piece of 12 ga to attach the bushings.
Any suggestions?
Thanks
Any suggestions?
Thanks
