Suspension question 4
chappy444
on a 1975 spitfire 1500.
can anyone tell me what the tourqe spec is on the bolt that holds the tie-rod lever to the vertical link...
not the nut that hold the stub axle and the tie-rod lever to the vertical link...
i am looking for the spec for the other one that also helps hold the break shield on as well.
it would be part number 16 on the right side (spitfire) diagram here;
https://www.victoriabritish.com/icatalog/sg/full.aspx?Page=117
thanks for the help.
Bill
Haynes lists the "steering arm to stub axle carrier" . Torque 65 ft lbs Is that it?
