aeronca65t
Take a careful look at the Spridget A-arm in the photo below and note the round, threaded reciever area where the fulcrum pin screws in. Under this area you will see a teeny, tiny crack.
This is my second one like this in less than a year. I've also had fatigue cracks on the chassis pick-up points where the A-arm mounts. I clean and inspect the suspension on a regular basis. You could easily miss this if you don't look carefully. This was fixed last week.
Many of our cars are 40+ years old and this sort of thing is to be expected (especially when you run sticky race tires). Good idea to inspect your suspension once in a while!
Hi Guest!
