I have a set of rebuilt H6 SU's that I would like to put on a stock 4A motor. I had a set of new "RH" needles and no stock needles so I installed them in the carbs. When I do the initial start up how far down should I turn the mixture nut seeing as how the needle is rich. Normally it's 10-12 flats down.
I can't actually try this because it's -30 here with the windchill and I don't have a heated garage so I'm kind of speculating about what will work when Spring comes. Also would I be further ahead to use a TR3 distributor in this setup because it would have a better match in terms of distributor advance. Or am I just looking for trouble trying this setup?:eagerness:
