dklawson
Yesterday I got a call from #1 son that his '72 Spitfire will not start. He said that the dash warning lights would come on and he could hear the electric fuel pump running but when he turns the key to the start position they all go out and the pump goes silent. Since he didn't have a volt meter I told him to check to see if the headlights came on, which they don't. I then suggested he turn the key to the run position so the dash lights and fuel pump were on, then turn on the lights to see what happens. The lights and pump shut off.
That tells me the battery is totally flat. I suggested he have a friend jump start the car. When they tried this he said the car still wouldn't turn over and that now the ignition warning light didn't even come on. I asked if they hooked the jumper cables up "backwards" but he assures me they didn't. We will see.
I am headed to the university today with a trunk full of tools, parts, and the battery from the GT6. I suspect it is the generic aftermarket alternator that is on the car as the battery was replaced in the spring. We had to install the aftermarket alternator (which was a spare supplied by the PO when we bought the car) when the original Lucas 5-wire alternator died through some failed diodes (badly assembled rectifier plate... not apparently a true electric issue). I am taking a Ford Fiesta alternator with me. I bought the Fiesta alternator to have as a spare for the Mini and the Spitfire but I have never tested it. Hopefully it was rebuilt properly, works, and can use the same belt.
We had the aftermarket alternator installed before and I removed it when some intermittent charging problems surfaced. Hopefully that is all that has happend again. I plan to do a few basic tests, then install the GT6 battery, hopefully start the car, and make some voltage measurements. The Fiesta alternator may happen in the parking lot if necessary should the voltage tests dictate it.
I know we'll get this sorted quickly but I am looking for other things to check when I get to the car today. It's raining a bit outside and I am getting older and don't enjoy working in the cool damp weather. If you have other ideas for things to check I welcome your suggestions.
