Jim_Gruber
Bugsy had some issues two months ago with fuel pump, and distributor cap that needed to be replaced. Local LBC Shop bailed me out on these and Bugsy has been running fine in the short times I've been aboe to use him since.
On Monday I fired him up for a short run around to do some errands. I began getting a slight miss and noticed that hte tach did not seem to be registering RPM's properly. Thought need to check tach connections and wrote the slight miss of to not getting driven much in last two months.
Tuesday I got another chanch to drive Bugsy and discovered miss was getting worse. Seems to idle fine but any request for power gives me a pronounced irregular misfire. Now cap and wires were replaced, I'm not sure on rotor and yes I've heard about the bad rotors that are out there and plan on ordering a pair from Jeff at Advanced Distributors.
I'll check and make sure all wiring connections are tight. The fit of coil wire to distributor cap I don't like. Rubber boot possibly pulling center wire out of the coil. I'll work with that today but other than checking electrical how does one tell if I got a bad rotor. British Car Day in Dayton is next Saturday and Bugsy wants to go.
