kcbugeye1275
Sat. was cold(15) with a drizzly freezing mixture in KC. In my garage, I had pretty much completed my rewiring and moved on to the reworking of my later master brake cyl. I'd cut the pedal box out for the new master before the repainting of the engine bay with the addition of a brace under the new location of the new rail on the master structure. My buddy John had frabicated an alum. plate to cover the open area and yesterdays sucess was the installation of all this. The failure was tring to repipe everything. I couln't find the 4 way splitter (its gotta be somplace). The lines I took with the later master don't really seem to be all lining up to were the front ones end up. I'm hopeing that a nights sleep on the project will find the splitter and then I can see the solution to all the lines leading to it. Also, when all this didn't work out, I started rebending the fuel line from the elec. fuel pump (upgrading to 1/4" id) and my bends with my bender were kinking. It was time to give it up, besides, when things weren't working out the garage seemed more cold.
