ArtQ
I have a 62 BT7 that was delivered without overdrive. My goal has been to restore the car to original as it was built. I have been told that I can substitute a different rear end (a 341 or 354 not sure which), get the same rpm reduction at freeway speeds as if I had overdrive without any "visible" changes to the car (easy pumpkin swap). I was also told that the only problem I might run into was a mostly useless first gear (which I never use anyway).
Any insight or help?
thanks
Art
thanks
Art
Hi Guest!
