DatsunDave
Hi all,
Firstly, sorry for not owning a British car...
I own and race an old Datsun 1600 (or Datsun 510 in the USA) which is fitted with Hitachi "SU clone" carbs - basically a pair of Japanese-made copies of HS4 SU's. I'm currently upgrading these to genuine British HS6 SU's and have a few questions I was hoping someone could help with.
Firstly, how much wear is "too much" in the throttle shaft ? Is there a specification or some sort of empirical measurement (ie xxx thou deflection) ?? I am rebuilding the carbs before fitting them, and have never had them running to know if there were issues with them. Throttle shaft play seems to be fairly minimal, I'd like to know for sure before deciding whether to get them rebushed.
And secondly, I have had someone with a near-identical setup to mine suggest "BAZ" needles as a good starting point for tuning purposes, but my carbs are fixed needle rather than the "swinging" BAZ ones. Is there a way to convert the swinging BAZ needles to be able to be used in the fixed-needle carbs ? Otherwise, what is the best way to determine a close equivalent - I've downloaded a few of the SU needle comparison programs, but I'm not sure how much variation in needle profile is OK before there are noticeable performance changes?
Thanks in advance,
Dave
Thanks in advance,
Dave
Hi Guest!
