TR2/3/3A su jets
sp53
Removing the Jet assembly from under a SU carb. I am curious how other remove the Jet Assembly. I would like to leave the carb body on and then pull of the chamber and piston then undo the jet assembly. I am not concerned about the re-centering of the jet at that point, but more about getting a good seal on the base of the carb. I remember in posts where people would slide the jet out to polish it.
Maybe pull the jet back as much as possible like the choke is out and then run the adjust nut up kinda tight and then undo large 13/16 nut with the cork seal and the carefully reinstall the whole assembly.
Looking for ideas
Platinum
That usually leads to a leak at the cork seal. Best way is to just bite the bullet and bench the things. Go through 'em completely then. Centering the jets is fairly critical and the centering anvil supplied in the "kit" pouch makes it much simpler, too. Those kits are mostly useless except for that little anvil & the wrench to adjust the jet height. If the SU in question is older, or of the spring-tensioned type, check the jet orifice for ovality as well. Seen more than a few jets worn to the point they pass more fuel than supposed to due to needles riding on the jet opening for long periods of time. Nearly impossible to get them to run correctly with that condition.
G SU HS6 Carburetors Needle Jets Selection Austin Healey 3
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
GTP1960 TR2/3/3A Question about SU H6 jets? Triumph 4
I TR6 Windshield washer jets...placement and installation Triumph 1
C Grose jets Spridgets 5
F Adivce on how to center jets of SU HD6 carbs Austin Healey 3
S TR2/3/3A Gross jets tr3 Triumph 7
TR4nut H6 carbs -jets sticking Triumph 15
J Float needle jets leaking! Austin Healey 8
aeronca65t Jaguar--Jets Stadium Spotted 1
H Washer Jets Austin Healey 5
G Are all jets the same size in a carb family? Spridgets 14
Nelson SU jets now centered Spridgets 7
KVH TR4/4A Sticking Accelerator or SU Jets: TR4A Triumph 7
hondo402000 Weber DCOE jets needed[to borrow and return] Austin Healey 2
hondo402000 DCOE Weber jets needed[borrow and return Jaguar 0
hondo402000 TR6 TR6 40 DCOE Webers Jets needed to borrow them Triumph 3
Got_All_4 TR2/3/3A TR3 Grose Jets I Need Convincing Triumph 20
JPSmit Grose Jets -? Spridgets 7
R weber 32/36 dgv, selecting jets, air correctors? Spridgets 15
rulle7 Windshield washer jets Spridgets 0
Kirk_Fisher grose jets Triumph 17
Luke_Healey Recentering the jets? Spridgets 37
don62 SU HS4 head jets adjustment MG 12
Woodie winshield washer jets Spridgets 1
SilentUnicorn waxstat jets Spridgets 0
R grose jets or not? anyone else Triumph 13
S TR2/3/3A Tr3 jets leaking on S.U.s Triumph 5
E Access to washer jets on '79B MG 0
Patton Grosse Jets Austin Healey 5
