I'm in the process of rebuilding another set of SU HS6 carbs for my BJ7 and sourcing some parts. The original needle jets are marked "BC" which correspond with a standard jet, as opposed to lean or rich. Supplier is suggesting to replace with rich jets due to modern methanol gas. What would you suggest, standard, rich or keep the original jets? Is there a way to check the old jets for wear? Thanks!
