RickB
Don't know how many of us with Spridgets try and use these HIF4 carbs but I've just today finally understood how the jet richening / leaning mechanism really works.
After studying many diagrams and cutaways I've finally figured it out.
Turning the screw clockwise richens, counterclockwise leans them.
Here's why:
There's a pivot in there and a spring (#24 & #25) and an L shaped lever and the screw (#21) lets that lever lean out toward the outside of the body or pushes it in toward the center. In toward the center lowers the jet while out toward the body raises the jet. Moving the screw anti-cw raises the jet and cw lowers it. Finally I "get it". BTW currently my car is running with the screws turned almost all the way in, due to an error on my part on just exactly which direction I should have been turning to achieve which results.
Diagram of the metering screw and associated parts:
From this larger diagram of the whole carb:
This cutaway drawing (on the right) was very helpful:
Here's why:
Hi Guest!
