SU HIF 44 crab problem
marcuscrackus
Hi All
Today i was out in my Landy which has a Rover 3.5L V8 lump. I lost most of the power and could not get over 30mph. After investigation i had fuel running out of the float overflow pipe on me left carb (i have 2 on this engine). So obviously i had lost one half of the engine. Does anyone have any ideas of what could be the cause? I am a novice with anything to do with engines soplease be gentle.
Could i be right in thinking the float maybe stuck? The engine starts ok then goes lumpy after a few seconds and then fuel starts to run out of the hose.
Many Thanks
Mark
trrdster2000
Mark, the needle and seat may be stuck, give it a good rap with a good size wrench near the bottom corners you can wrack it. a 5/8 or 3/4 should be the size, not a hammer, unless you have a tack hammer.
If that's not it, drop the float bowl and push the float up to make sure it's cutting off the gas.
Wayne
LarryK
The winter isn't gentle on these older carbs. Get some carb cleaner spray and check the float needle seats. If not familiar with these carbs or uneasy to try, look around your neighborhood or area nearby for an old British car and ask for help. If all else fails get on-line and find the nearest Rover club and send an SOS, these guys love helping as the will want to see you Rover.
M
marcuscrackus
Cheers boys i am having a look at the weekend. luckally when i brought the truck it had a spar old engin with a set of carbs on. I am going to use them as a bit of practice before i go to town on the good ones.
GBRandy MGB HIF float chamber seals MG 6
R 1275 engine with SU HIF single carb Spridgets 9
R HIF Carbureter British Motor Corp 2
wkilleffer MGB Anyone still use HIF SU carbs? MG 12
RickB General Tech Need pictures showing how to connect choke on HIF carbs. MG 2
B TR6 Hitachi HS6 HIF rebuild/TR6 Triumph 1
PAUL161 72 HIF Butterfly - Moss Part Number MG 15
PAUL161 HIF Throttle Disc MG 10
A HIF tweaking Spridgets 11
M HIF 44 Choke Spridgets 10
H HS4 to HIF inlet manifold question MG 2
PAUL161 Doc, Tony, HIF SU434 Carbs Vers. SU493s . MG 4
PAUL161 SU Carbs HIF-4 # AUD 434s What are they off of ? MG 5
PAUL161 HIF-4 Question ? Need some answers! FOUND ANSWERS! MG 0
PAUL161 Question -- 25D-4 vac hose connection with HIF-4s MG 7
A new guy-74 B, HIF question MG 15
D HIF carb info request MG 3
Moose33 newbie question about HIF's MG 2
Thor What Needle Used for HIF-6 on 1500 Spridgets 3
Thor HIF-6 Needle/Jet Recommends for 1500 Spridgets 0
W MGB 73 MGB HIF Hoses MG 8
A HIF 4 Carbs MG 6
weewillie land crab anyone? Other British Cars 7
T TR4/4A TR4 seat buffer problem Triumph 5
Carlbanan56 MGB High rpm problem MG 27
Sarastro TR4/4A Convertible top installation problem Triumph 12
J TR4/4A Strange Problem Fitting Inner Fender Triumph 18
B TR2/3/3A Possible differential problem Triumph 3
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
E Gearbox problem Other Cars 0
A Rivergate slave problem Spridgets 3
Govtslug TR6 Clutch Problem Triumph 21
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
M 1977 MG Midget 1500 Problem Spridgets 8
KVH General TR Transmission Problem Triumph 3
DrEntropy W123 Benz recurring problem Other Cars 16
J MGB Idle problem MG 4
tr6nitjulius TR6 TR6 No 1st/2nd problem/solution Triumph 4
Got_All_4 TR6 Throw Out Bearing Fork Problem Triumph 7
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
E MGB MGB heater motor problem MG 3
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
T TR2/3/3A Help - Cooling system problem Triumph 7
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
ROARRR Is there any problem swopping in a 3.0 in place of the 2.5 L engine in my Jag X Type? Jaguar 0
T General TR Cluthch problem / challenge Triumph 4
