smaceng
I'm putting the finishing touches on the engine before I spark it. Ive set up the carbs, good piston drop, choke works, with fast idle OK. It seems that the choke will not stay engaged, but tends to slowly dis-engage. I know my old, old MGA had a twist feature on the choke to hold it. Is there anything I am doing wrong by looking at the photo. Do I need to add springs on the choke levers?
thanks for your help. 1275 with HS2 carbs.
Scott in CA
Scott in CA
