Tinkerman
I just added damper oil to the carbs. The front damper went back in with a little hydraulic pressure as I expected. The rear dampesr had much lessor hydraulic pressure. Apporximatly same amount of oil (marvel mystery oil). Do I have a problem or does it not matter? If I have a problem, is it a damper problem or a carb problem?
Found no help in the SU manual.
Your thoughts and commentary are greatly appreciated.
Thanks, Tinkerman
Thanks, Tinkerman
