RichC
Since I'm not an expert at the 'rat-a-tat-tat' fuel pumps and have a 75 MGB with one that will not pump ... I proceeded to purchase another. BTW ... have done the electrical checks and switch under the dash and all is fine ... I think. (about 11 volts) I installed the new pump and turned the key to hear the quick 'rat-a-tat-tat' noise for about 2 seconds before turning it off. All was looking good.
Next put new fuel in the NEW tank, check all my lines and turned the key until the pump turned off. Looking good I thought. Next was to fire up the car in which it did only to stall after chugging for about 5 seconds. (first since '92) After attempting a restart and realizing that I was not getting fuel began to diagnosis the system. I took off the new fuel filter (full of gas) and attempted to let the fuel pump click some fuel into a can. Nope ... wouldn't come on. Recheck electric and took off fuel lines again blowing them out to see if something has plugged ... didn't.
I've now got the two fuel pumps in front of me and am trying to figure out what to check? Putting 12 volts on either pump results in the same thing ... silence. Your thoughts?
