Ok, I got it to run. Timing is still off so I need to tweak it. I had to advance it further than where I thought it should be. Just wanted to tell you before the posts piled up /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
Still fighting one spitting carb. I think I need to re re readjust the float level. If I understand the way these carbs work that should cause a rich mixture.
What reinforces this solution for me is that when I changed out the jet bearing half of the fuel leaked out. On the first start after that it ran great until the bowl filled up again.
Sure is nice to hear it run! I even have 60PSI oil pressure at idle.
