mountainman
The front carb choke will not return all the way home once it is pulled out. I have disconnected all the linkage and even lifted the piston to make sure it was not sticking on the needle. These carbs have been completely rebuilt but have sat for about 6 months. You can shove it home with a little pressure. Could it be the sealing gland washer or conical washer is to tight?
Thanks
Greg
Thanks
Greg
