I should have added that my friend, a TR4 owner and retired professional mechanic does not use the vacuum advance on his car by choice.Unfortunately, the vacuum on the TR2/3 is placed so it sees no vacuum at idle, but then begins as the throttle valve opens and uncovers the hole in the throat. In other words, if you just hook it to the intake with full time vacuum signal, it will have a flat spot as you accelerate off idle. Unless you are very careful, drilling a tap into the front carb could end up badly.
