Are the jets properly fitted in the float bowl body? If not the needles cannot create a good seal because they will not land flush in the opening. On my Courier (HD6 carbs) I had to take a bit off the length of the jets to get everything sealing up nicely and maintain the right fuel level in the bottom of the carb.
A properly fitted and matched jet and needle and a non-leaky float should close against 2-4 psi. Again on the Courier I use a Holly blue fuel pump and take the fuel pressure down via a regulator mounted just before the carbs to 4.5 psi with no problems.
Hi Guest!
