JKent
I recently got my BJ7 going again,and find that the carbs are running way too rich. Worked fine while breaking in the cam, at 2000-3500 RPM, but isn't doing well otherwise. Electronic fuel pump is putting out 4 psi, so I stopped it down to about 2 psi with a pressure regulator, still runs rich, even with the jets cranked all the way up, level with the bridge. No evidence of sunk float or stuck needle valve (no overflow), but runs okay if fuel is trickled into the bowls by intermittently running the electric pump. Float levels set per the manual (nylon floats, 1/8" clearance). Any suggestions?
Hi Guest!
