Rut
The Weber/Pierce I had on my Bugeye had been jetted correctly by the PO and the performance was good, no flat spot either. From everything I've read the Weber has a little better wot, the dual HS2s are better all around, and the single SU is somewhere mid pack. David Harrison (Gundy) probably has the most experience with all these carb combinations since I think he's tried everything! Iirc, he has gone back to the dual HS2s on his modified 1275.
Rut
Rut
